Clinton Cranston best machine built big block, NA wedge style head, over 1200 hp.
If you had a race class which was NA, 2800 lbs, door slammer and no cubic inches what do you think guys would build? I bet there wouldn't be a single SB car in the lanes. People would show up with mountain motors.
These are answers to the simple question of "most HP". If the question is "most HP per CI" or "most HP per lb of engine weight", then it gets more complicated.
If the results don't match the theory, change the theory.
