Originally Posted By cdwmotorsports
Originally Posted By Cab_Burge
Don't use either one of those between the fuel tank and electric fuel pump tsk I learn that lesson the hard way thumbs
What electric fuel pump are you using and what size fuel filter micron rating size do they recommend to use between the tank and pump?
Why shouldn’t I use them between the fuel cell and fuel pump? All I see anymore is how there needs to be a filter pre and post pump.
I am currently using a Holley blue pump. I have never seen anything stating a micron rating for it.
The Summit 100 micron between the tank and pump will work just fine. I have that exact one before my Aerospace Components 400gph pump. Fuel pressure and volume don't fluctuate one bit.
I don't have one after the pump and have not seen a need for one.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
