Originally Posted By AndyF
Looks good. If everything can get machined in the same setup then the accuracy goes way up. Lifter bores are in the correct place and in the same line as the cylinder bores and stuff like that. From what I've seen, some of the other folks move the blocks around from machine to machine for different operations which is why the lifter bores sometimes don't point in the same direction as the cylinders. With that type of machine capability you guys should be able to get everything dead nuts on.
iagree
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
