Originally Posted By AndyF
If you do make a low deck block in the future you should just keep the 440 size mains in it. No reason to go with the smaller mains since there aren't good bearings for the smaller size anyway. And anyone who needs that strong of a block will need good bearings and a strong crank.
low deck 440 mains, thanks Darren for the block...It will happen just give it time. yes it is a solid block for my dragster.
