Here in Aust the authorities , police , are a lot stricter .
Mine is my daily driver .
10.70 with my 440 , 10.25 before the 505 block gave up .
Solid flat tappet cams , under 11.0:1 comp run on 98 pump gas . 440 has .520 nett lift cam , 505 has .600 nett lift
Have a new World block going together , 505 , should run 10.20s
Car has 5 point rollbar no rear seat , needs bar for track . Not enough rear head room with bar so no rear passengers allowed for street .
Runs on pro bracket radials , take them out of the boot and swap at track , no race slicks on the street .
Raced through the exhaust , dumps at diff , my class also requires mufflers .
Still has stock interior with bench seat and heater demister .
Tex
