Hughes has a little cheat sheet in the tech section of their website. Pretty much adjust every valve you can that is on base circle before turning the crank. Might be worth a look.
Chris I will check that out. Yes it is gonna come down to adj as many of em that are on B/C with as few (crank) turns as possible till I get all of em. & as I have been told I am likely being too picky over this. I got other issues going on that are skewing my mechanical thinking right now but it will pass. Thanks Chris & thanks guys. EDIT I cant find their cheat sheet, only the chart that has you adj (1) in & (1) ex at every 1/4 turn (8 times).
