Originally Posted By fast68plymouth
What else besides the heads, rockers, head studs, and likely pushrods.......are required to do the swap?
Pistons still okay?
Headers I think are supposed to fit.
Valve covers?
Intake manifold?
Requires different header. TTI now makes them.... pricy.... 1200 ish
Different valve angle..... custom piston?
Pricy rocker gear
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
