No way did they get close to anneal temp if the bearings did not spin
you not all the post heat temp processes they go through
are they still round
torque the bolts down a couple of times with the same lube- do they change dimensions?
mag is not going to show you anything
if a little out of round- which happens to even non hated rods after a few runs
cut the caps flat and re hone
do not worry about the dimension a the parting line it can be a little wide
who makes - actually makes- these rods
no colour pics?
