You might want to talk to an8sec70cuda (Chip). He has a stock weight 70 'Cuda with a KB 572 that runs 9's on motor, 8's on spray. It's a street car. He has his combo figured out very well and can probably give you some pointers on the suspension and drivetrain. You would need the same, if not more power out of your engine, and like previously stated, a stock block will not live long in that environment.
