Originally Posted By madscientist
With the correct clutch it will. Again, you can use a sintered iron disc on the street. Been doing it for years. Done correctly, an 833 will live behind a bunch of power as long as you don't beat the hell out of it with a junk clutch and a heavy flywheel.
what does the clutch have to do with it when you exceed the torque rating of the transmission by hundreds of ft. pounds? I have broke more third gears than I can count, never one time was my foot on the clutch...... Clutches don't break these Hemi 18 spline Transmissions. It's a heavy car that hooks, and with a lot of power.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
