i'd try a step hotter and do some leaning on the mix. can't see the strap to check timing. i'm finding the gasoline to be gummy; or at least the fuel in my area is. if there's a black "runny-gum" on the plugs let them sit over night and see if the gum dries up. I don't think oil will dry up but gas might.
