When I had my 383 magnum rebuilt for the first time 25 years ago , I reused a Mopar 284/484 cam and lifters that I had installed the year before
Machine shop said cam and lifters looked fine , well
Lasted about a month , same situation as yours
Installed a new Mopar 284/484 cam and lifters , never took anything else apart on that new motor
25 years later , wiped out that same cam and lifters when I tapped a piston with the intake valve on my newly installed Edelbrock Heads
Long story short
432 Stroker now
Machine shop said all my bearings , crankshaft , cylinders looked good for a 25 year old motor
They did the short block , gave me all the old pistons , rods , crankshaft , bearings etc.
I took the oil pump apart this winter (This 25 year old motor had 75 psi hot at cruise and 35 psi at idle)
Inside the Melling HV oil pump it looked like someone took 60 grit sandpaper , a grinder , jack hammer you name it
I have no idea how it still rotated , it was that bad
Like I said , rest of the motor , bearings looked pretty damn decent
Replace the oil pump for piece of mind
