On straight banjo 1050's .082-.084 on the primary should be close I would think and .090-.092 has worked on the sec. side w/the pvcr's in the .080 range..........Then there's the t-slots and if they're not exposed at idle then I've been between .065-.070 on idle bleeds and .026-.028 on highs w/.040 ifr's...........It's a damn juggling act for sure..........
The 84 is too rich!I am down to a 72 going to a 70 on pri side.
