This thing must be pulling on the acc squirters.The fuel % goes up as I push on the throttle in neutral in the garage and steady pt throttle/rpm a/f is stable at rich down to 10/1 a/f with 12/1 at just past the idle circuit.I blocked the power valve to start then put smaller jets in to be sure it was none of those 2.I have some tube squirters to put in.The float is at 3/4 so I still need to lower that.
