When you're talking roller cams and street cars...... Depending on what the particular requirements are, will determine what the priority list looks like.
When the requirement is reliability suitable for 10-12k miles a year...... That gets moved right to the top of the list........ And as such, will dictate what most of the rest of the components will end up being.
For me, that would mean smooth lobe profiles with modest lift that will operate happily with moderate spring loads...... Along with top of the line lifters and premium endurance springs.
You make stuff so complicated.
Would you consider using something like a PAC 1232X beehive w/ a light retained on a street roller profile like the extreme energy? Say up to 6500 rpm.
