I went with the Morel High rpm versions, $940.00 from Hughes, they work good so far, car ran 11.33 @ 121, 4100 lb Charger, no tuning yet, they are a little noisy when cold, you can adjust them .020 from bottoming out of the plunger, & they also recommend no heavier than 5-40 oil, I am running 10-40 Lucas racing oil with no problems. pulls great over 6200.
my car is a street car.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
