Originally Posted By cudaman1969
Originally Posted By Old School
Originally Posted By JAKE68
I have a problem with understanding why someone needs a 650 hp motor that is only going to be street driven and never raced and wants to be reliable???? That is a lot of strain on parts to make that much power to be pounded on at low speeds for bragging rights. lie!!! and leave it stock. That's my .02. Don't get me wrong I like a lot of hp but i use it for what intended.
Don't try to understand it! People do it everyday. It's called Hot Rodding.
You will really like mine then. 588" 960 horsepower 100% Streetcar. Has nothing to do with bragging rights. It has to do with the right to do what you want to do with your car.......
So, what cam are you using?
A solid roller. .800" 290@.050. I also use the isky bushed roller lifters. I have found needle bearing roller lifters do not last on the street......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
