I've driven it a few times and worked on a few bugs. I think I made a mistake by putting an aluminum flywheel in it. The car works great once it is over 2000 rpm but it really doesn't like driving slow. Even with the steep first gear ratio it will start lugging at low speeds. Some of that could be the carb since I have a 1050 on there at the moment. I'll see how much of that lugging problem is solved with the EFI. If that doesn't solve it then I'll have to pull the engine and swap flywheels.
