Originally Posted By MuuMuu101
Originally Posted By AndyF
I weighed the car today and found out that it is heavier than I thought. Good news is the weight distribution is pretty good. 51% up front and 49% in the rear. The gas tank is almost empty so if I filled up the tank the car would have a 50/50 weight distribution front to rear. The bad news is that the car is almost 3800 lbs with nobody in it. If I filled up the gas tank the car would weigh over 3800 lbs.
Isn't gasoline about 6 lbs/gallon? I'd imagine with an extra 12 gallons, it would weigh almost 75 lbs more.
Still cool you'd be able to achieve almost 50/50. How did you do it? Fiberglass body panels?
No fiberglass, the body is all steel. The 50/50 weight is due to having the battery in the trunk as well as having a fairly lightweight engine. Aluminum heads, aluminum intake, aluminum carb, mini starter, aluminum water pump housing, aluminum radiator, etc.
