I didn't use a universal tap and die set. I bought specific bottoming taps from tool & die companies. They were a very good fit. Maybe you could tap your blocks to the next size up?
try using form taps they work much better than a standard tap and a lot more accurate sizing.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
