Originally Posted By Dave Hall
I wouldn't worry about it as I found the reverse lever to be pretty independent and was able to adjust it in the car just like you would adjust an auto trans. cable. GREAT NEWS! The side cover was the problem! It was able to swim up nearly an 1/8 inch and everything is free and shifting normally! boogie Thank you so much guys! This forum and it's members are just the shyznit! up up up The owner called me "one diligent mother@#$er!" Haha! He's off to the exhaust shop to get a small rattle over the rear end dealt with and fine tune the clutch adjustment. One happy dude that didn't have his vacation plans ruined because of you guys! biggrin See him in Van Nuys this weekend. I was planning on going and had a room and everything but racing called and I'm off to Dallas for a double div. 4 event tomorrow morning.
Good thing you did that , hopefull first , if you pulled the detenet without taking the cap and spring and ball out FIRST and instead pulled it out and an assembly you'd be fishing around for the ball as it rills off into the bottom of the trans case ... DAMHIK
running up my post count some more .
