Without the tool it's trial and error. Use a 1/4" rod to align the 1-2 and 3-4 levers with the housing, then install the 1-2 and 3-4 rods. Play with the Reverse rod adjustment until you can shift into Reverse without having to move the shifter for or aft as you pull the shifter towards you.
The INTERNET, the MISinformation superhighway
