Yes the trans. was gone through but sat awhile during the resto. When I adjusted the rod length, I put the shifter in reverse, moved the lever fully into reverse then screwed the rod out until they went together. When we pulled the shifter and trans. out of reverse there is a weird "clack" sound from the trans.
