On the dyno it worked out great. We'll need to get the engine into the car to see how it drives on the street with that tunnel wedge intake. It has a lot of torque down low but I'm not sure how it will work right off idle when lugging 4000 lbs around with a 3.55 rear gear.
When you jump on it though it is going to think it has Hellcat power under the hood!
