HOLD ON GUYS!
What part of the flywheel needs welding? Did the starter ring come loose? Was a bolt hole damaged? Was it broken in half and he's trying to put it back together?
If it's not a deep fissure being welded on the surface of the flywheel it's likely okay to repair.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
