Originally Posted By sgcuda
Originally Posted By MR_P_BODY
But it could be the last time you have to mess
with it.. I've been real happy with my Holley
EFI multi point after I made some wiring changes
and I do love the aspect that if I want to change
something its just a few clicks on the lap top
wave
On a carb, there is no wiring to change. And whatever happened to the guy on this site that was running EFI and the system crapped out? Never heard what the problem or the fix was. At least, if a carb goes bad (and I doubt it will go bad enough, fast enough that it will quit running), you just borrow your buddies carb and keep going. Who keeps extra injectors, TPS, MAP, Temp, O2 sensors with them?
Do you carry around extra injectors, tpc, map, temp and o2 sensors when you take your modern daily driver down the road?
