Originally Posted By fourgearsavoy
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer shruggy I have always wanted to try it so here is my opportunity.
I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base.
Thanks guys
Gus beer
Yep, and if you run the WIX racing a 3" flows more than your present carb iirc and I run one w/a 1050 or 1150 dommy w/out issues. Plus the added plenum volume usually helps accordingly.......... beer
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
