Originally Posted By fourgearsavoy
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer shruggy I have always wanted to try it so here is my opportunity.
I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base.
Thanks guys
Gus beer
Hope it helps you. Do yourself a favor and either install the fitting before installation or at least check out the threads. Most of these spacers are mass produced and the taps are way past being worn out. Easier to check on the workbench than while bending over a fender.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
