Originally Posted By Guitar Jones
Two carbs in that kind of application actually require less fuel flow to keep up because the jets are smaller. I know sounds weird.
If the motor makes more power with two carbs., and what Mopar V8 doesn't, it has to use more fuel, correct work
It takes X amount of fuel to make each HP, increase the HP output and the fuel consumption has to increase to make that power shruggy
