Re: ((((((((((Gbob's Dyno #'s))))))))))))
[Re: 66coronet]
#237563
02/27/09 10:49 AM
02/27/09 10:49 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Those are good numbers. If the Victor heads are as tall as Indy heads, you are going to run into a hood clearance issue with that spacer on top of that intake. I know my vent tubes are burried into my scoop with SR heads, a 440-2 intake, 1 inch adapter and Dominator. Good luck with it. How much does your car weigh?
I did some measuring, with the raised port heads, which add an inch of height, plus the taller super victor manifold, the carb flange is 7 1/2" from the valley tray. The victor 440 on the rpm heads (prior combo) was 6 1/8" tall.
I tried a dominator on a 2" adapter before, so that put that setup at 8 1/8" overall height and the carb was about even with the hoodline. The wilson spacer is actually 1.5" tall, so it would put the carb about an inch higher (9" total height).
With a weight loss regimen, both for me and the car, total weight should be around 3600. Maybe 3575 by summer. ![](/ubbthreads/images/graemlins/whistling.gif)
