Awesome! How much more is the lightweight crank option from 440 source?
I think it was $300 and the crank was 6lbs lighter....I like it. Revs very quickly. After driving a 440 of the same cubes, same heads, same compression for 7 years....its noticeable when you touch the gas pedal.
I have another 400 block now that I scored for $300 and I also intend to build a 383/496 stroker with a procharger if my Hemi sells. All of them will get the light weight 4.25 crank.
