It all depends on the budget of course but if the money is available I'd buy aluminum heads for that engine. The modern chamber design in the aluminum heads will allow you to run pump gas and you'll lose a bunch of weight off the nose of the car.
You should be able to sell those Stage IV heads for a decent amount which will offset some of the cost of the aluminum heads.
