1969 Road Runner 4 speed 3.91 gears, 440, 10.5:1 CR, Stealth aluminum heads, Comp cams XE284 cam, Edelbrock RPM intake, TTi 1 7/8" headers/ 3" exhaust. Mostly street driven and the occasional trip down the 1/4. The engine made 501HP/514TQ on the dyno with the engine shops dyno carb (not sure what it was).
I currently have FAST EZ EFI 1.0 on the car, but the fuel pump died on the way home from a car show yesterday. The EZ doesn't work great with the cam in the engine, and I'm not sure I want to upgrade to a multipoint EFI system.
So... what carb do you recommend? I was thinking around a 750-850CFM double pumper with annular boosters, but not sure who makes the best carb.
Thanks in advance.
