Strange has an 1147A housing end that takes the 3.15 bearing with the normal mopar bearing ID. You will have to change brakes though, or modify what you have.
Years ago Strange and MW both told me they don't recommend pro race axles on the street. Because of the hardening process they said over time with potholes and such it's possible for the axle to fracture or even bend just outside the bearing.
