Going to 40 spline stuff may require a different case with a larger 3.250 side bearing. Not enough room in the smaller bore for the axle, spool and bearing. Sometimes it just makes sense to step up to the good stuff to begin with. Gun drilled 40s are lighter than solid 35s and substantially stronger.
If the results don't match the theory, change the theory.
