the only reason to have Stealth heads is for the stock look. if you should ever damage a Stealth head & it requires welding, you might as well throw it in the bin & buy a new one. They're cast from a low grade aluminium that does not respond well to welding. I have repaired a set of Stealths that needed welding but the cost was more than a new head. go figure.
