Did a low compression 440 with Stealths replacing 452's. Fun little ride until I grenaded the 440.
Took those heads, sent them off to Modern Cylinder Head for CNC port, and slipped them on a 505" stroker shortblock.
They did have new (not Source) locks and retainers installed by a local machine shop when I bought them.
Very mild hydraulic Howards roller and 3.54 gears.
Best of 11.19 @ 121mph with 60 ft. still needing work in 3,600 lbs. with driver.
4,000 street miles and tons of dragstrip passes in last two seasons.
'63 Dodge 330 11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs. 10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
