I'm aluminum all the way. I have a steel engine and an aluminum engine. They both have the same heads and the steel one makes 100 more HP than the aluminum engine. It takes a lot more HP to make up for the extra weight. The aluminum engine is faster with less porting, less camshaft, less compression, less flow, etc.
