Did the 6-pack have a better cam then the 4 barrel? I think the biggest advantage is the hood. What rpm did you get out of the 340, where did it fall off? Picking your brain for my combo. 70 Duster 340 avs. Why would the stick be rated more hp then the auto? Good luck
