I reread your post and see that you are runnimg the MSD. With most MSDs you should not have a ballast resistor.
Where are you powering your MSD from?
I would still do what I suggested in my post above, but to the MSD power wire.
I do suspect that the way you have the box powered you are losing voltage to the MSD because of a bad connection in the bulkhead. I suspect that the MSD power is being taken off of the original ballast wiring.
PM me if you would like some additional guidance.....
