I'd like to see some of these 1500 hp bracket race engines I'm hearing about. If, you're in the Pro classes you need the good crank, If, you're out with the Street Outlaws ,maybe, you need one. Like the one guy said, they use a BBC crank forgings, who uses mopar size bearing anymore? All this whining and crying for nothing. Buy a raw forging and get it cut by your favorite crank grinder.
