My combo last year was a 68 cuda I pulled a 440 out of a 76 new yorker changed the intake, put 500 lift voodoo cam in it, 830 holley carb, 4;11 gears stock 727 with shift kit I put in it. Went 11;97 @ 118 I was shocked if you run the numbers on some of the other web sites that calculate horspower based on e.t it works out to 430hp which i know its not making.
11.97 is exactly where I want to be. Great combo. Thanks for sharing it. Do you remember the duration on the cam? I think 4.10 gears are the way to go too. Thanks
1965 Belvedere II 440 4psd 4.10 Driver
1966 Belvedere II Race Car Project
1970 Duster Street Car Project
2003 Hemi Ram Quad Cab 4x4
