Man I am OK with it
I have seen heads this year that had the "two step" line down the middle where it was two different levels from what looked like two passes--then at a friends the other day I saw the block with the same deal--again I say I have never bought any other heads that were new and needed surfacing so be it with Indy I don't care
Maybe the step in the deck lines up with the step in the heads to clamp the head gasket better!
I think you just got an unfinished block. If you paid for a finished block, then there is an issue that needs to be resolved.
