Not to defend but to clarify. If (underline) the deck surface is cut by Indy it is done in one pass as are the heads. They have one machine for blocks and one for heads and they both make the cut in one pass....but that's after sleeves are installed. The machine that cuts them just prior to the sleeves does not. I also know that they do not set the sleeves proud of the deck because well....Russel the love muscle.
Just hang on mopar world. It can only get better!
