How do body shops put these things together without checking trim and other panels for fit?
That's the difference in finding a shop that knows what it's doing, I usually make the customer a bit perturbed on my constant requests for trim, glass, emblems, panels, etc, etc that I want to test fit, that will be used or changed out during the restoration build, I put enough effort into building, bodyworking, blocking for weeks on end on primer, paint, colorsanding clearcoats, that the last thing I need is panels/components, trim,glass or emblems that don't fit, plus having to modify or redo work already done!
Mike
