Yes I agree also & if the ball as called just goes in I out of the brush holder the retainer is broken or damaged. sounds as if you have a few serious needing some parts.The bushing seized on armature shaft may have damaged that too. You might opt to find another one or send it out to see IF IT CAN BE REPAIRED. I as well as ACR2000 restores them. you can see some pics on my website.
