Hello Moparmojo,
1st problem I see is that the brush holder end plate is on the shaft.NORMALLY IT IS BEHIND THE FACTORY PRESSED IN BEARING RETAINER IN THAT END PLATE. Does that bearing turn freely on the armature shaft? Once that bearing gets out of that end pretty impossible to get back in properly.
