Probably 6.4 (bigger bore) although the Hellcat block is stronger. 6.4 truck block is apparently the same block as the Hellcat but with the bigger bore
Edit: my bad, I thought the Hellcat had a smaller bore for more cylinder wall thickness, it's still a 4.09 bore
