I think your car is bad running cal tracs and leafs watched a couple of your videos and was wondering what trans are you running since you are leaving at around 5k
I run a two speed glide 3000lb..I leave the starting line between 5 and 6000 RPM depending on the track conditions..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
