Alston A-arm front with coilover's and the motor is back a bit. Not stock floor or firewall. It does have stock doors, window glass, dash, wiring, steel fenders and steel trunk lid. It's not a typical tube frame "panel" car. It was not built to compete in any heads up classes since I couldn't afford to run them. Quite certain it would run well under chassis cert with a nice shot from your fogger.
